ФОТОТЕХ
AsmiTools - сборник Lisp программ от Александра Смирнова
Александр Смирнов
размещено: 05 Марта 2010
обновлено: 06 Марта 2010
3CORD.LSP - Fills the table in co-ordinates of 3DPolyline vertexes. Marks vertexes of 3DPolyline accordingly data in the table by digits or letters. Look section 'ADJUSTMENT' for acquaintance with options.
AMOVE.LSP - Moves multiple attributes simultaneously.
ATNUM.LSP - This program for fast dynamic numbering by a block with single attribute. To number a suffix and a prefix can be added
ATRON.LSP - This program reacts to an insertion of the block with attributes (INSERT command). After block insertion and rotation it set an angle of attributes equal 0° and allows to move attributes to the necessary place.
AWIDTH.LSP - Adjusts necessary width of attribute.
BRI.LSP - Break one of intersected objects.
CBLOCK.LSP - This routine replaces (or adds) blocks to others blocks.
CHATT.LSP - The program for change attributes with the chosen value in dynamic and ordinary blocks.
CMDCOUNT.LSP - The program is used for testing of drafting skills of AutoCAD users. It shows the report on quantity of the used commands and time spent for the test drawing.
CURSE.LSP - This program will transform various types of curves to LwPolylines with specified long segments. It works with LwPolylines, Circles, Splines, Ellipses and Arcs. In LwPolylines arc segments will be transformed only.
DIMBRICKS.LSP - The program for bricklaying dimensioning. Writes the basic size over a dimension line, and quantity of bricks under a dimensional line.
DISLAY.LSP - The program is intended for processing files which were are exported from Microsation. It creates layers according to color, linetype and lineweight and distributes objects on these layers.
DOFF.LSP - Multiple doubleside offset with possibility of delition of source objects.
DOVER.LSP - This program draws aligned dimension and requests to overide measurement. Do not ask why. So one guy has asked.
DWGCOLLECT.LSP - collect copies of a drawings for revision to the folder specified.
ELEN.LSP - tool for calculation of total length of LINES, POLYLINES 3D-POLYLINES, CIRCLES, ARCS, ELLIPSES and SPLINES.
FHAND.LSP - Converts objects to 'freehand' style. For LINES POLYLINES, CIRCLES, ARCS, ELLIPSES or SPLINES.
HYPSYN.LSP - Synchronises invisible attributes and hints of hyperlinks.
INVIS.LSP - Makes objects temporarily invisible and returns visibility.
MPL.LSP - This lisp draws 2 - 16 polylines simultaneously.
MULLION.LSP - Draws window mullions.
NUM.LSP - This program for fast dynamic numbering. To number a suffix and a prefix can be added.
ORDI.LSP - This lisp for labeling X,Y coordinates with standard _DIMORDINATE dimension. The dimension properties is defined by current dimension style and variables DIMSCALE, DIMLFAC and DIMDEC.
ORDY.LSP - This lisp for labeling X,Y coordinates and point numbers with standard _DIMORDINATE dimension. All coordinates and point numbers keeps in the text file "Drawing_Name.csv" in a format: "point_number, X-coordinate, Y-coordinate, 0". The dimension properties is defined by current dimension style and variables DIMSCALE, DIMLFAC and DIMDEC.
OUTLINE.LSP - Transforms width polylines to it boundaries (outline).
PATLAY.LSP - Allows to select group of layers with the help of wildcard pattern string and to do with them following actions: On/Off, Lock/Unlock, Freeze/Thaw, Highlight (select).
PDIM.LSP - This lisp for dimensioning of several LwPolylines simultaneously. The program works with current dimensional style. The distance of the dimensional text from a polyline is equal to multiplication of height of the dimensional text (DIMTEXT system variable) on a variable 'tOff'. You can change value of 'tOff' in the program beginning, after note.
RENLAY.LSP - Allows to rename layers quickly without Layer Manager.
RENUM.LSP - This program converts TEXT, MTEXT and ATTRIBUTES in numbers with a prefix and a suffix.
TABCORD.LSP - Fills the table in co-ordinates of LwPolyline vertexes, and also the centres and radiuses of arc segments. Marks vertexes of LwPolyline accordingly data in the table by digits or letters. Look section 'ADJUSTMENT' for acquaintance with options.
TALON.LSP - Allows to place a text in parallel or perpendicularly a Line, Polyline, LwPolyline, Arc, Circle, Ellipse or spline.
TTC.LSP - The program copies the text from: DText, MText, Tables, Dimensions, Attributes, Attributes, Attributes Definitions, DText, MText and inner block's DText and MText to: DText, MText, Tables, Attribures and Attributes Definitions. There are Multiple and Pair-wise modes.
VARSPY.LSP - Traces changes of variables and prints in the text window as: [Variable Spy] Variable_Name Old -> New It is used for tracing of changes of variables at work of various programs (AutoLISP, VBA, ObjectArx, .NET)
VICO.LSP - This lisp program copies visibility state from one dynamic block to others.
XPIPE.LSP - Fast 3D-pipe extrude
XTUBE.LSP - Fast 3D-pipe extrude.
Комментарии 1-7 из 7
Djur , 05 марта 2010 в 19:56
можешь, пожалуйста, описание лиспов выложить? какой для чего? хоть в двух словах...
Djur , 06 марта 2010 в 20:42
а можно на рус.))) а то нем. все всремя учил)))
SLADE , 06 марта 2010 в 21:34
спасибо проге translate.google
3CORD.LSP - заполняет таблицу в координатах вершин 3DPolyline. Знаки вершин 3DPolyline соответствующие данные в таблице цифры или буквы. Смотри в разделе НАСТРОЙКИ 'для ознакомления с параметрами.
AMOVE.LSP - Переместить несколько атрибутов одновременно.
ATNUM.LSP - Эта программа для быстрого динамического нумерацию блок с одним атрибутом. К числу суффикса и префикса могут быть добавлены
ATRON.LSP - Эта программа реагирует на вставке блока с атрибутами (INSERT команду). После вставки блока и ротация его набор атрибутов угол равен 0 °, и позволяет двигаться атрибуты в нужном месте.
AWIDTH.LSP - регулировка ширины необходимым атрибутом.
BRI.LSP - нарушит одну из пересекающихся объектов.
CBLOCK.LSP - Эта процедура заменяющий (или добавляет) блоки других блоках.
CHATT.LSP - программа для изменения атрибутов с выбранным значением в динамичных и обычные блоки.
CMDCOUNT.LSP - программа используется для проверки навыков составления документов пользователей AutoCAD. Она показывает отчет о количестве используемых команд и времени для теста рисования.
CURSE.LSP - Эта программа преобразует различные типы кривых для LwPolylines с указанным долгом сегментах. Он работает с LwPolylines, кружки, сплайнов, эллипсов и дуг. В LwPolylines дуги сегмента будут преобразованы только.
DIMBRICKS.LSP - программа для кладки размеров. Пишет основных размеров над измерением линию, и количество кирпича в мерной линии.
DISLAY.LSP - программа предназначена для обработки файлов, которые вывозятся из Microsation. Создаются слои по цвету, тип линии и толщины линии и распространяет объектов на этих слоях.
DOFF.LSP - Multiple doubleside смещения с возможностью delition из исходных объектов.
DOVER.LSP - Эта программа рисует соответствие размерности и просит overide измерения. Не спрашивайте почему. Так что парень спросил.
DWGCOLLECT.LSP - собирать копии чертежей на доработку в указанной папке.
ELEN.LSP - инструмент для расчета общей протяженности линий, полилиний, 3D-полилинии, окружности, дуги, эллипсы и сплайны.
FHAND.LSP - конвертировать объекты в 'руки' стиль. Для линий полилинии, окружности, дуги, эллипсы и сплайны.
HYPSYN.LSP - синхронизирует невидимым атрибутам и намеки гиперссылки.
INVIS.LSP - делает объекты невидимыми временное и возвращает видимость.
MPL.LSP - Это Lisp ничьих 2 - 16 полилиний одновременно.
MULLION.LSP - многомиллионные обращает окно.
NUM.LSP - Эта программа для быстрого динамического нумерации. К числу суффикса и префикса могут быть добавлены.
ORDI.LSP - Это Lisp маркировки X, Y координат со стандартными _DIMORDINATE измерении. Измерению свойств определяется текущим стилем размерность и переменные DIMSCALE, DIMLFAC и DIMDEC.
ORDY.LSP - Это Lisp маркировки X, Y координат и точку со стандартным _DIMORDINATE измерении. Все координаты точки и сохраняет в текстовый файл "Drawing_Name.csv" в формате: "point_number, X-координата, Y-координата, 0". Измерению свойств определяется текущим стилем размерность и переменные DIMSCALE, DIMLFAC и DIMDEC.
OUTLINE.LSP - Преобразование ширины полилинии ее границами (Outline).
PATLAY.LSP - позволяет выбрать группу слоев с помощью подстановочных строку узором и делать с ними следующие действия: On / Off, Блокировка / Разблокировка, замораживания / оттаивания, Highlight (Выбрать).
PDIM.LSP - Это Lisp для размеров нескольких LwPolylines одновременно. Программа работает с текущей мерных стиля. Расстояние от мерного текста из полилинии равна умножения высоты мерной текста (DIMTEXT системных переменных) на переменную 'франт. Вы можете изменить значение 'франт' в программе начинается после записке.
RENLAY.LSP - позволяет переименовать слои быстро, без Layer Manager.
RENUM.LSP - Эта программа преобразует текст, MTEXT и атрибуты в числа с префиксов и суффиксов.
TABCORD.LSP - заполняет таблицу в координатах вершин LWPOLYLINE, а также центров и радиусы дуги сегмента. Знаки
Disney , 07 марта 2010 в 11:43
SLADE, может всё же стоило, проста дать ссылку на переводчик
http://translate.google.com/ или http://www.translate.ru/
Я сначала тоже хотел перевести, но даже ручной перевод, без запуска самой программы был бы не совсем корректным, а время, что бы протестировать каждую программу я не нашёл.
roman56 , 17 марта 2010 в 18:04
Спасибо за ваши лиспы
меня очень заинтересовал лисп TALON, но если можно
изменить его так, чтобы выровненный текст писался в том же размере и фонте, что и выбранный
заранее благодарен
Walkmax , 20 мая 2012 в 17:06
«Lisp видимости государство»
Эти плоды машинного перевода проверять надо хоть иногда перед публикацией.
vad311 , 24 ноября 2013 в 17:19
TABCORD.LSP иногда не верно считает координаты центров дуговых сегментов
0.07 МБ
